OneCaratRed
This spring, when I tried to use my 5 HP Tohatsu 4 Stroke kicker, it will start with the choke out as it always has, and then continue to run as long as the choke is out.. When at idle throttle setting (trolling) it will continue to run UNTIL CHOKE eventually goes all the way in.. then it stalls.. Have ruled out bad fuel as this motor is fed from same filter/separator as main engine.. has new internal fuel filter in motor.. where to start troubleshooting this issue is the question? Fuel line? Fuel Bulb? Orings in motor connection..or is it even a fuel question.. Ideas??
