"I have an early 90's 5hp
"I have an early 90's 5hp 2 stroke tohatsu, cannot get fuel to carberator bowl. I have cleaned and rebuilt the carb. I have changed the rubber goods in the fuel pump. I have cleaned the internal tank and cleaned the filter in the tank. I have good flow from the tank to the pump.
I put a fuel bulb in the line from the tank to the pump and can squeeze fuel to the bowl. Engine runs good, even under load until the bowl goes dry.
All of the orifices, holes and channels in the carb system flow air easily. I have tanken the fuel pump off and can blow through the pump easily. When I apply a vacuum to the pump inlet it closes as it should.
What have I missed that will not allow the fuel to enter the carb bowl?
I have cleaned the carb several times.
I am at a loss."
I am at a loss."
