munkachunka
Hi all,
I am hoping you can help me. I have a 2006 Volvo Penta Gi300j that is giving me grief.
Symptoms:
Engine will not idle - it tries to start but does not fire.
I can get the engine to start by disengaging the gear and giving the engine some revs. Once started it is not happy and the revs keep pulsing (for example between 4000RPM and 1000RPM) depending on the level of throttle.
What I have done:
I have swapped the Idle Air Control and that had no effect. My engineer misdiagnosed the issues, in hindsight it could never have been the IAC as that would have only generated problems at idle.
Plugs recently changed, distributor turns although I am not sure how fast it should be turning, cap was a bit dirty and I have given it a bit of a clean. Fuel appears to be okay as I depressed the little test valve and fuel spurted out. I used a jerrycan of fuel to rule out air locks.
Many thanks, Stu
Symptoms:
What I have done:
Many thanks, Stu
