In my last post I was advised to check the wiring on the injectors. Looking at the wiring diagrams in the Diagnostic Manual I realize I don't really understand how these things work.
I appears that all injectors have a terminal connected to a hot source when the ignition is on (same one that drives the ignition coil and fuel pump relay). Then the other terminal on the injector coil is connected to a "Fuel Injector Driver" in the Engine Control Module (ECM). The Driver will fire the injector by connecting its side of the injector coil to ground for the appropriate number of milliseconds, at the appropriate time.
My problem is that on the 5.7 the ECM only has two Drivers, each with a single wire "output". Driver "A" connects to injectors #2,#3,#5 and #8. Driver "B" connects to injectors #1,#4,#6 and #7. So it appears that the only control the ECM has over the injectors is to fire an entire injector bank of four every time one of its cylinders goes on the intake stroke. This makes little sense to me and I must be looking at something wrong. Does anyone know how this thing controls which injector gets opened?
Perhaps my assumption that there is one pulse on each intake stroke is wrong. Perhaps the injectors pulse 4 times for each cylinder power stroke (spread out evenly over the whole cycle)??
