I have a Silverton 310 Express with 2 x 5.7 mercruisers (1996) We had both engines out and did a full rebuild ( pistons, rings, bearings, new Edilbrock carbs etc etc.)on them as they had been submerged. Both engines run very well at start up, but when warm (10 mins) one engine looses power and eventually cuts out. Fuel has no water in it but there is no spark.
I took it to a Mercruiser dealer who checked it over and said the ECU was the problem. I bought 2 of these and put 1 on each engine. - problem still exists so I replaced the coils, and 1 ignition switch which was a bit iffy. Problem still exists!! I am running out of electric parts to replace!!!
Any tips on where to go next? I have thought of coil leads and so while fishing and floating for 2 hours I swapped leads from 1 to the other and then the faulty engine started. But it then cut out after about 15 minutes and the other was still ok.
The tacho's are both faulty and thought that that could be where my problem could lie but it appears to be more heat related as the engine cuts out when it warms up.
HELP!!!
HELP!!!
