flatheadcat78
Looking for some ideas. I have a throttle body fuel injected 5.7 mercruiser. Model 0L093978. Anyways when i hit the key it will crank and then die. It will repeat this over and over again. If you give it a little throttle she will crank and idle. Fuel system is good, pickup, lines, filter, injector pulse. I pulled the IAC out of the thottle body to look at it. It was pretty clean, but it was fuel soaked?? I was a GM tech years ago when the trucks had the TBI motors and I never seen a IAC that was wet. So what gives? I now these systems are similar but why is the IAC wet? TB problem? Fuel regulator problem?
And yes the boat runs great otherwise. Just the starting issue.
Thanks for any help! Don
