5.7 ltr. Merc 1990-Thermostat Housing replacement-hose placement
Richard57
I purchased a new thermostat housing assy PN#860256A1 (Design III- Alpha) for 1990 Merc Cruiser 5.7 Ltr engine Alpha 1 (S/N OC679275).(Port side).
I do not have an updated schematic showing the new hose routing, for the Design III THERMOSTAT HSG. I am confused as to where to attach the 4 hoses on my original Engine to this new Thermostat Hsg.
There are 2 hoses that connect from the thermostat hsg to the underside of the exhaust manifolds, and 2 more hoses that connect from the thermostat Hsg to the top at the exhaust elbow. Therefore my question is do I eliminate the top hoses on the exhaust Elbows or downsize to a 3/8” dia hose to fit this new thermostat housing?
Also I would like to know the proper placement of the temperature sending unit on this new thermostat housing
My part supplier could not answer my questions and advised me to contact you, I would really appreciate a quick response as I am perplexed on what to do
The temp sender goes on one side of the thermostat housing. Doesn't matter which side
You will plug the elbows where the hoses use to connect above manifold
Need flow thru gaskets part number 863724 between manifold and elbow (assuming you don't have riser extensions)
Pic is for Big block so pay no attention to item with Note 1 on it.
