If it's a EFI it has a connector for a scannerThe boat doesn't have any scanner hook up
It's on top the motor and normally near the ECM of thermostat. It will be black in color and have a plastic cover over the connector.Where would the hook up be?
A better question would be "Once you find it, what will you do with it?".Where would the hook up be?
What makes you think it has an IAT?intake air temp sensor. Is the throttle body dirty? mass airflow sensor? Check the air filter for a mouse nest. Do you have a scan tool?
