At first I was checking the elec fuel pump. (Pumps during crank but dies w/. power lost) then i had a light on the purple wire to the choke which lights when cranking but not on run. I will then lost all power to the Ing. switch & gages & the engine dies. Turn the ign. off for a moment & have power back. I must have a short somewhere I am going to check the oil sender, main fuse & engine grd. and all the wirng. Any other suggestions? TIA
Update jumped the oil presure sender & seems to be idling ok I also removed & spayed the carb. I think I may need a new ing. switch as the power is still intermentent.
Changed OP sender, It will start right up and run 1 minute & die at that time I also lose power to the gages & ing. switch. after another min I have power. Any clues?
