stretchmanPA.
I have an '86 Wellcraft 23 NovaXl with a mercury 260 alpha1 (5.7 liter) TB ignition syst. The distributor cap cracked and had to be replaced. In the process, one of the cap screws, (rearmost) broke off. I had to remove the distibutor assy. to drill it out. In the process, I damaged the ignition sensor and had to replace it. New ignition sensor, cap, rotor. Reinstalled distributor. I don't have a manual so going off gm/mechanical experience, preset the timing to 8' BTDC. Engine starts fine, but now has a complete lack of power, misses. Won't run up over 3000rpm. The odd thing is, if I hold the trim button, say down, with the trim all the way down, so it is maxed out, the enging smooths out and gains 500rpm. As soon as I let the button go, the miss comes back and engine slows down. I went thru most of the electrical syst. trying to find a short. Can't pin down a problem.
What is the correct initial timing setting, and any ideas at all on the miss, running issue, and why would putting a load on the trim pump make the engine run fine??
Help.
Help.
