5.0LX surging/stumbling
keviwe
5.0LX 230HP 4bbl Rochester carb recently started stumbling, then surging (or running normal). Starts normal, Idles fine. Sometimes accelerates normal, sometimes not normal (less power). Sometimes runs normal at 3,000 rpm sometimes it faulters. Doesn't feel like a spark plug misfire. I have newer genuine Mercruiser plug wires, dist. cap, rotor and AC Delco spark plugs. I have just changed the fuel filter (thinking it was water in the fuel (or alcohol separation), added several different fuel additives (in different tank fill ups) to remove water from gas, but nothing has helped.
Sometimes it runs good, sometimes it doesn't.
Carb has never been touched, so I will rebuild carb.
Any other ideas?
Can an ignition coil get "weak" or "weak intermittently"
Thanks for your suggestions!
