By spark test, just what do you mean? Spark quality.... or spark timing?Thanks guyjg,
today i,m going to perform a spark test and a compression test just to be sure
after that i,m going to do the injector test.thanks for the tip.
Well, that's a good thing!Rick, there are no changes to hull and prop condition. the boat doesn't stay in the water so there is no growth.
+ 1 ............WPAGE,
We must be careful what we tell others to do with chemicals here.........
What you do is your business but to just say use acetone with no explantion is not considered good practice.
There are too many viewers who may not understand the full impact of using or handling chemicals such as pure ACETONE and may cause more damage than good.
If acetone is the "base" for many fuel cleaners than maybe suggest the actual cleaner that the acetone is the "base" for. That way they are using a premixed packaged product with INSTRUCTIONS on how to use it.
Pure acetone vs a mix may not be a good thing for many....just sayin........
...Using a solution of 1:160 I noticed a slight swelling of the gaskets, just enough to be noticeable. 1:160 is DOUBLE the maximum recommended ratio for acetone usage. ...
Kghost 4:15 We must be careful what we tell others to do with chemicals here
Rick 7:22 Chemistry..... be careful!![]()
The thing with open forums is that someone may poke their head in and read one tid bit only.
Give a man a fish and he'll eat. Teach a man to fish and he'll survive...or something like that...
