Goodtimes1
Hello community - I am requesting a little help...
I have a 1998 Sea Ray 190 with the 5.0l efi and Alpha drive.. My problem started last fall, but since it was the end of the boating season I left it until this spring... What I have happening is the tach will start jumping around wildly.. Occasionally the engine will start running rough.. I found one of the spark plugs was fouled - replace them all (thought I probably had the problem fixed - nope).. I kept a close watch on the tach and what is happening is when the tach has a solid reading (any rpm) the engine runs fine.. When the tach starts jumping around, if the reading stays below about 5200 rpm the engine runs fine.. If the tach starts jumping above about 5200 rpm the engine starts running rough, when the tach reading drops blow 5200 then the engine starts running fine again.. I am guessing the ECM is seeing this same high rpm signal and rev-limiting the engine until the signal drops back down.. So I suspect the problem lies wherever the tach signal is generated.. I'm not sure, but I have heard the tach signal can come from the alternator or the ignition system.. I don't have any problem keeping the battery charged and the voltage is in the normal range.. The only other symptom I have seen was last fall, occasionally the engine would die when idling.. It would start right back up and if I bumped it into gear and gave a little throttle then it would not die.. I have not seen that this spring - the fouled plug may have been causing that issue..
I have checked wiring connections over the entire engine and under the dash and found nothing loose or corroded...
I don't see how it could be a tach problem - I don't think it would feed back to the engine and cause this type of intermittant problem.. I will probably disconnect the signal line to the tach for my next trip out and see if it makes any difference..
Any ideas would be appreciated... Thanks...
