stillcrazy36
The inside starter bolt is frozen. The starter shows evidence of being sprayed with salt and must be replaced. Looks like the water supply hose to the stb. exhaust manifold leaked due to a faulty clamp.
Both starter bolts were frozen but I had access to the outside one and was able to heat and apply PB blaster. It lossened up in 1/2 hour but I don't have access to the inner bolt casting to do the same thing. There no room for an impact tool. Tried tapping the end of the bolt with a hammer. Spraying the general area (Hail Mary), used as much of a cheater bar as I could get in the space available.In the Marina we used small butterfy impacts to drive screws. I don't think that it has enough torque but the vibration might help. ?? PS this is not my first GM starter to remove but so far the worst !
Any ideas?
Any ideas?
