I need help to do timing. this engine has ignition module inside the distributor. using timing light, I set it to 8 degrees before TDC at 750 rpm and it does not runs good and backfires through exhaust. it runs much better when set at like 20 degrees advance. Very confusing because manual calls for grounding pur/wht wire to do base timing. I looked all over for pur/wht wire and just not there. Ordered new distributor, rotor, coil, ignition module and hoping I get lucky. I appreciate any help with this puzzle.
