Got hold of a 4hp Mercury possibly 1978, cannot find the exact year on the serial number sites listed (s/n 8072749).
Won't start. Has spark, compression is 90 psi on both, seems to backfire when trying to crank and some smoke comes back out of carb (Carb has been cleaned and float seems ok etc).
Found a manual which states the rich/lean needs changing to be richer but this doesn't help.
The original model had a fuel tank which isn't there now so using a remote tank with primer bulb. After lots of reading on here, I checked the crankshaft key which is intact and not worn.
Anyone have any other ideas and also maybe any info on this motor serial.
Many thanks
Many thanks
