"Hi all,
working on a 1980
"Hi all,
working on a 1980 Evinrude 4hp (E4BRCSS) that has me a bit stumped at the moment. Not sure if these two problems are separate or interconnected:
1. I can usually get the motor to start and run at WOT but if I bring down the throttle, it loses revs and dies. However, I can usually keep it running indefinitely if I ride the choke manually each time it starts to crap out. Starting usually involves numerous pulls of the cord and all kinds of manipulation of the choke and throttle settings.
2. The motor also seems to be overheating - within moments of starting up, the exhaust cover plate gets boiling hot (literally!). However, cooling water would appear to be circulating (see below).
The motor has an integral fuel tank and a carb with the single needle valve for the slow speed mix. I don't know the history of the unit, but supposedly it's been sitting in the previous owner's garage for years.
Work done so far:
- Full carb clean and rebuild even before I started it up for the first time
- Cleaned fuel tank valve and replaced fuel line+filter
- Cylinder decarb with PowerTune spray
- Replaced & gapped plugs
- Carb needle valve backed out about 1.5 turns from seat, however before I can get it to run better I haven't even gotten to the point where I can think of fine-tuning this adjustment...
- Replaced water pump impeller
- Tested water circulation with a hose into the tube, and it comes out from the exhaust holes as expected.
- Water tube is definitely inserted correctly in the pump housing.
- Also, droplets of spray are apparent from the exhaust when pulling the starter cord.
Not quite sure where I should be looking next... Any hints appreciated!"
working on a 1980
"Hi all,
Work done so far:
