My 2002 Merc. 496 Mag has an i
My 2002 Merc. 496 Mag has an issue with oil overheating after a long haul (1 hr + running) and dropping oil pressure. Water flow out of port side exhaust significantly less (40% less) then starboard. Riser and exiting water warmer on port side to the touch. Had a new manifold installed on port side when winterized last season. Had marina look at this and they said I had a blockage (Seaweed /Grass) in power steering cooler which they replaced but still have less water flow issue. Overheating oil issue used to occur after 20 min now after 1 hr+. Could this be a worn water pump from blockage or issue with oil cooler? I was told they checked oil cooler and rest of system with no obstructions found. Raw water flows from power steering cooler to oil Cooler to heat exchanger on port side. Continuous alarm sounds till throttle brought back to neutral with significant oil pressure drop according to gauge. Engine temp will maintain 150 degrees. Where should I start looking to correct this problem? Thanks in advance for troubleshooting help.
