"Well after 2 months of repair
"Well after 2 months of repairs, exhaust manifold,(leaking cooling chamber into the exhaust and into the head head) completely rebuilt head upgrade to 4" heat exchanger, new plugs, new lifters I started it and everything seemed to be fine, but a fair bit of steam out of the prop. The temperture on the gage did not go about 140 degrees, not under load of course and kept RPM's below 1500. Does this sound Ok temp. with a 160 thermostat So now I am going to replace the impeller kit. I have the complete upper and lower drive off and in my garage so now do I use any lube on the impeller, and what to use on the gaskets on "O" rings. Should be ready for Pender Island again next summer. Cheers and thanks"
