I have heard not to use automotive head gaskets for marine applications. Is this a fairy tale?
If the engine is Raw Water Cooled, that is correct information.
For a Marine Engine that is fitted with a Closed Cooling System, a high grade automotive head gasket will work.
Also I have heard the Sierra gaskets don't hold up & to use only Mercruiser. Is this BS also?
The Merc gasket might be specially designed for Cast Iron cylinder head against the Aluminum cylinder block.......... I am not sure.
Perhaps check out the link that Bt Doctur posted (post #9).
