454bs will not tach up consistently
ibanez540r
"Ok, here we go. First off I a
"Ok, here we go. First off I am new but have been reading this forum for some time and have gathered tips and help from a lot of you, but now I've come to signing up and making a post because I'm running out of ideas and everyone I talk to is at a loss!
I have a 1990 30ft Carver Allegra with twin 454 350 v drives FWC. I recently bought the boat and had it shipped in to Ohio from NY. No hours meters but the marina knew the previous owner and said "low hours". Always maintained from the marina's service. However the boat has not been out in a couple years but had a fresh tune-up and was winterized. They did advise the one motor had the carb recently rebuilt and the other was probably due.
So... I get the boat in, bottom paint, clean etc. Put it in the water, and motors fire right away. Run and idle great. Topped off fluids etc. Get the boat out and go to throttle up and they would hit about 1500RPM and not go any further. Even if I went WOT motors would not tack up. So I would go back to idle and work it up again, 1500 sometimes try for more and then start bogging and actually loose RPM. This went on for a while. Decided it was probabley some OLD fuel. Ran it at low rpm for a bit trying to burn it out. I then put in some octane boost, nothing.
Here's were it get's weird... Between putting in additives, and topping off with some fresh gas, on occasion I would go out and keep the same problem, sometimes getting to 2000RPM then dieing off. Sometimes one motor after struggling would come alive and Tach up and pull strong through 3-3500 as the other starts going up and then would bog and die down making me get off the opposing engine. So they would go back and forth, mostly never being able to tach up, but then spuratically pulling strong when the other was not. FINALLY I got them to both pull strong at same time and get on plane. ...Cruising for a min and a motor would start fading and bogging, come back, go away. SO let off. Try from an idle and back to square one. No RPM over 2000.
You get the point. In the mix of all this I did pull the filter/seperators and they were dirty and one did have some water in it. New installed, no differance. Topped off with 15 gallons of fresh in each tank when they got down to 1/4 to 1/8. Nothing. Oh, I did rebuild the other carb and this also did not help.
Today, went back up. went out once or twice for 1/2 hour, same prob no RPM's. Tried one last time before leaving, they both open up to 3500 and plane out. Try again nothing, almost wouldn't even tach over 1200RPM.
So initially I thought bad fuel, which I'm sure is partially the case and not helping. But if it was fuel do you REALLY think it would be speratic!? Same fuel going into the motor the whole time why would it be good every now and again!?
Also the motors rev great and tach all the way up in neutral
I should add...
- tune up is aparent because of nice clean wires and cap.
- motors are electronic ignition
- I tried to squeeze rubber lines to see maybe they were being sucked shut, they felt stiff and strong.
??? ... I don't know, I was almost starting to lean to thinking there is a collapsed exhaust baffle??? Are there even baffles in the exhaust? I know the fuel is bad, because of smell and age, but additives and ran pretty empty and topped off with fresh.
PLEASE HELP ...I'm counting on you guys, my season isn't very long up here in OHIO!"
You need to make sure with a t
You need to make sure with a timing light that your getting the distributors to advance as the RPMs increase.
as far as a rusted stuck advan
as far as a rusted stuck advance spring? Wouldn't the advance not be an issue with the electronic ignition?
Even electronic ignition must
Even electronic ignition must have working advance within the dictributor(s) to properly fire the cylinders under higher RPMs. If you put your timing light on #1 and watch the timing mark while reving you should see the timing mark move. If they are rusted and not working you may have just found the problem.
"Ok, I kinda worded that last
"Ok, I kinda worded that last reply wrong. My question is does an electronic ignition still have a spring that can corrode, or is it controlled "electronically? If so what is replaced to fix the advance curve if this is the issue?"
Check the anti siphon valves a
Check the anti siphon valves and the pick up tube(s) at the tank(s). Both of these have a tendency to block up after a long lay up.
Ron
"Also check if there is a tiny
"Also check if there is a tiny filter hiding in the carbs (if they are Quadra-Jets. This tiny filter is famous for plugged up.) Also, I hope you have a good, METAL can, in-line filter AFTER the fuel pumps!
Jeff"
"Jeff, I am aware of the scree
"Jeff, I am aware of the screen in carb filter. I replaced the one when I did the carb. It was pretty bad but even with the brand new one it made no differance. I havn't checked the other but, if it wasn't the issue with one motor I'm not thinking it would be the case.
What else ya got? :)"
My CC Explorer had a screen in
My CC Explorer had a screen in the syphon tube in the tank. I had a problem with the engine running well for about 20 minutes and then struggle for gas. I found the screen blocked with what looked like a dust bunny. I used a 5 gallon gas can and stuck the gas line into it and ran the engine for a while this is what lead me to believe there was an issue with the gas it ran fine on the 5 gal can. I ended up having to pull the tank and clean it. I got rid of the screen too. Thank you ethonol
"I would also agree that this
"I would also agree that this may be a fuel starvation issue, anti siphon valve etc. It is easy enough to determine if this is the problem and quickly eliminate it. Get a pair of gas cans and fuel hose and substitute them for your fuel tank, run the spare fuel line to the separator input and run the engines, if this doesn't cure it then you at least know the problem is from there to the engines."
"Thanks, I like the idea and w
"Thanks, I like the idea and will try it out next time I go up (hopefully this weekend). My only concern with the fuel starvation issue is... why woul dit act starved most of the time, but every now and again run strong?"
"Hi Guys...My 2 cents...1- wit
"Hi Guys...My 2 cents...1- with a timing light check to see you are in fact getting distr. advance regardless how it achieves it. 2- Run the engines on portable gas can (like used for outboard motors). If engines still dont run right, you now know that old fuel is not the issue(only issue). When my starboard wouldn't start, I exchanged carbs...then it rans fine. Carb was the problem. Ethanol/gas is causing tons of problems...especially boats."
