"After refurbishing the heads,
"After refurbishing the heads, cleaning out the filter housings and replacing the distributor cap and rotor this RH rotation engine started & ran fine for 3 hours. Then began to surge(at first 200 RPM then wildly) and stopped. won't start since.
Cleaned the TBI fuel injectors (they were pretty gummy according to the injector cleaner). Timing is set per spec. Fuel is relatively fresh stabilized (sta-bil)no ethanol (tested for alcohol). Spray cone looks OK. Checked voltage at the fuel pump, seemed OK, replaced the fuel pump.
Pump runs for 4+/- sec when key on. Fuel pressure does not build to 20 PSI until I stop cranking - then it goes to 20 and drops to 0.
I am thinking fuel pressure regulator in the TBI, oil pressure switch, finding a mechanic with the code reader, or have I completely missed something simple? The other engine starts and runs OK but probably needs to have the injectors cleaned as well."
