CTII pilot
My port engine is running hot. It levels out about 180 at idle (starboard is about 160). But even at idle will bounce up to 210 and momentarily up to 220 and then will come back down again to 180. I never get an overheat alarm which I believe is set to 210. When I run it it will get up to 210 or higher after a few minutes until I bring it down to idle. I just got the boat and was getting hotter on sea trial. The surveyor recommended getting the heat exchanger boiled. I cleaned the sea strainer this weekend and also back-flushed the oil cooler.
Tonight I was going to switch out the sender lines to the other gauge to see if it was a gauge error. However, due to the way it wired I didn't want to pull it all apart tonight. The port oil pressure and voltmeter also momentarily pulse about a needle width every 15 seconds or so while the starboard gauges are rock solid.
Any ideas?
Any ideas?
