SeaJay1987
Here is a little history. 1987 Tollycraft with 454s. New boat owner and first thing I noticed in sea trials was the stbd engine does not give a whole lot of power. No more than 1700 RPMs. She also gives off a fuel sheen and you can smell the unburnt fuel from the exhaust. I have had 3 separate mechanics all say the same thing. They just can't find what is wrong. She runs but has a little vibration. All signs point to firing order and timing to me. Found the firing order of 1-2-7-5-6-3-4-8. Easy enough. But that is not what the engine has configured. Currently she has a firing order of 1-4-6-3-2-7-5-8. I tried to put it to the other firing order but she will not start. Even with starting fluid.
I have had 2 of the mechanics check timing. Replaced plugs and wires. All with no change.
So is my problem a crank shaft? Distributor installed in a wrong direction? Or just straight up over haul her?The previous owners stated it has always been like that (for 24 years). Any and all help is appreciated. Thanks!
