W
wej55
Guest
"I have a 1995 7.4 throttle bo
"I have a 1995 7.4 throttle body injected moter that runs up to 200* at idle. When you run up the throttle it cools right down. I have cleaned out the heat exchanger and the u cooler, replaced the water pump impeller and also the t-stat.Both engines appear to be discharging the same amt of water. The starboard eng water discharge is extremely hot.What next ?"
