zackfactor
I am working on a 1981 454 mercruiser which is having a cooling issue causing me to pull out my hair. the engine has new risers, manifolds, and heads. after checking and rechecking virtually every aspect of the cooling system, i have gotten the entire engine to cool with exception to the intake directly under the carburator. the heads, manifolds riders and both the fron and back of the intake are cool, however directly in the middle of the engine on both sides of the carb, the temp jumps up to almost 200 degrees within a minute of starting the enigine. any ideas on what could cause this, i have never seen anything like it an quite frankly i am lost. i have already removed the intake and cleaned it very thoughly and there was no blockage. this engine was converted to freshwater cooled with exception to the risers. could the freshwater pump be weak?
