"1989 454 crusader,converted t
"1989 454 crusader,converted to new Pertronix billet marine distributers back in august. Started having issue with module failure in unit. Factory said to check voltage with coil grounded,should be at least 11.5volts. Found 8.6volts on mine (key on not running). Did Crusader use a resistor wire from altenator to the coil? Did not find a ballast resistor in line so far."
