Velocity280
I'm having some issues with my new engine and hope someone has experienced this before and can help me out . Gen 6 454. I'm getting a temp of 150 under idle, which seems normal (140 thermostat, no bypass holes drilled). This is a raw water setup with a sea strainer and a bypass kit instead of a circulating pump. When I run it anywhere over 3000 rpm, it'll climb slowly to 180 on the gauge, then climb rapidly to almost peg the gauge at 250. I've checked the block with an infrared temp gun and the engine stays around 175. The oil lines read around 200. The gauge will drop if I raise the Rpms in neutral. Back down to 150 or so. Where should I start looking? Does this sound like a bad temp sending unit?
