team_mayhem
"I have read a lot of good eng
"I have read a lot of good engine tips on this forum for some time but don't think I have ever posted a question until now.
I have been chasing a temperature issue and wanted to see if you guys could share your thoughts opinions... I have a 1982 36' Egg Harbor with a pair of 454 Crusaders. The engines have about 1600 hours on them and the starboard engine has been running hot for as long as I can remember (I have had the boat for 8 years). I have been trying to solve the problem over the past month and have replaced the heat exchanger, elbows, risers, oil cooler, all hoses, impeller, and through hulls. The engine is 27 years old so the vast majority of that stuff was long overdue anyway.... The problem is the engine is still running hot. It's right at 205 degrees when running and 180 at idle. It will run up to 180 degrees within a couple of minutes of starting it at the dock... Oh yeah, I replaced the thermostat as well. I have an infrared temperature gauge and have been able to confirm that the temps on the gauges are accurate so that ruled out the gauges (or at least I think it does?
So by my calculations I've changed everything imaginable on the cooling system side of the engine (all in the last 30 days). That got me thinking about internal things that may cause it to run hot.. One idea being the circulation pump for the coolant? If the coolant isn't circulating would the engine run hot yet not overheat? The other idea that a friend had mentioned was that it could be head gaskets... If I am understanding the concept correctly he thought the exhaust gases could be getting into the intake side of the cylinders hence "super heating" the engine? He had indicated the fact the engine ran up to 180 so quickly while at the dock was an indicator of head gasket issues... I can say that from taking the temperature at the top of the intake just behind the carb the temperature is 257 degrees.
Anyway, I'm at a loss of ideas and don't know if either of the two ideas listed above make any sense or if you guys may have a recommendation before I go down another dead end."
