440 Chrysler frozen
peyton
"I am new to your group and se
"I am new to your group and seem to be having a few difficulties in getting my message posted correctly ---- so if this has been posted previously, I apologize.
I have a 1975 Century Arabian with a 440 Chrysler and have never had a problem with the engine - it only has about 850 hrs on it.
I didn't use it for about 18 mths and when I tried to start it I found water in the gas and could not get it to turn over. Unfortunately I didn't do anything after that and it sat for another 6 mths. I pumped out the tank and filled with fresh gas. When I tried to start it, it was frozen and all I got was a click.
I removed the plugs and filled the cylinders with a penetrating oil (PB) and Mystery oil and then let it sit for 2 to 3 days. I repeated this about 4 times and have only been able to move the engine a bout 90 degrees using a breaker bar.
Any suggestions as to what to do next??? Many thanks - Peyton"
your on the right track just k
your on the right track just keep working it slowly I have also used transmission fluid with great results. move it back and forth not only in on direction.
"help i need a exhaust manifol
"help i need a exhaust manifold for a 1979 440 oem style for my boat, any info. thanks, the port motor has a replacement manifold, but i dont know where to find it."
Peyton- Keep working the engin
Peyton- Keep working the engine by rotating back and forth with ATF. I suspect you have a cracked exhaust manifold that flooded a cylinder or two and set up some rust.
Steve Steve- I have 1 or 2 left over manifolds from my Century Arabian in good condition. Will sell cheap.
Dave
Dave
