"I have a 1991 Campion Allante
"I have a 1991 Campion Allante boat, 4.3L Inboard, 2BBL carburetor. I am getting water under the distributor cap and causing the engine to crossfire and misfire. Also when I pull the breathers out of the valve covers I am getting a small amount of steam along with the usual blow by. I have no water in the oil though which seems wierd to me. I think it could be an intake gasket leaking into the lifter valley and causing this steam. I also have done a compression test and that turned out well as all of the cylinders make around 160 psi.Any help would be appreciated."
