tyeefisher
"I have a 1992 Volvo penta 4.3
"I have a 1992 Volvo penta 4.3l engine modle 431b with a quadrajet carb and electronic ignition.I have had the following problem.The engine will start fine and warm up to 150.I start to plane out and hit 3000 rpm and the engine dies.I have gone thru the fule system and checked from the tank thru the carb.I replace the electronic fuel pump,replaced the water seperator filter and put a new rebuilt carb on.I thought it was a fuel issue but its not.When the engine dies their is fuel going into the carb just fine.The boat will start rightback up after it dies and will run for a short time and die.I checked the coil and have good spark.I have checked the obvious but can not figure out why it dies.The boat starts right up cold,runs at 150.It is starting to look like a electrical issue now.I have no idea what to look for next.Any help would be greatful. Thanks,Jeff"
