43L popping
C
casey meyers
Guest
"Finally got my project boat o
"Finally got my project boat out - runs and gets up on plane until about 10 min of running then pops back thru the carb. checked timing, was erratic so the sensor was replaced - so timing is steady now and correct. Valves seem to be adjusted ok - manual says lean carb but there is only a idle mixture so?"
"Mixture at normal cruise powe
"Mixture at normal cruise power is determined by main jet size and float level.
If the jets are correct, you could try raising the float level 1/4" or so to richen the mixture.
If this has been going on a while you may need to do a carb kit.
Rod"
"so we ran the boat again afte
"so we ran the boat again after changing float setting, re-torqing all the valves and it still pops - will replace the t-bolt4 module will have a carb rebuild kit in two days and will do carb - this is the most frustrating engine problem I have had - I should stick with diesels......"
Test the amplifier module per
Test the amplifier module per merc. procedure first to save big bucks. Timing is 8 deg. BTDC or it will backfire.
"I have a 2003 Carberated 4.3L
"I have a 2003 Carberated 4.3L Mercuiser that Pops thru the carb. I have checked the fuel changed fuel water seperator, put a carberator kit in it, Changed spark Plugs, Coil, Cap, rotory& pickup,Timed it at 10 degrees before top dead center as the book said. With the purple white wire grounded. The last thing I did is bought a high priced ignition control Module. It will idle but when I give it gas it starts poping thru the carb.I bought the book from West Marine and followed everything."
Michael:
Start a new thread
Michael:
Start a new thread for all to see and you'll get the most help. Are you sure it is 10 deg. BTDC and not 8 deg.? Are you holding the timing tight directly over the timing marks at 12:00 O'clock? If not it will be off a deg. or two.
