"Hi all,
I`m new here and I
"Hi all,
I`m new here and I certainly don`t mean to offend anyone or step on any toes, but I need to get the straight scoop from someone who actually and verifiably knows the differences. I`ve read back through several pages of posts concerning the 4.3L engine and as is typically the case on discussion forums, I`ve noted a trend by guys who were very recently asking questions about these engines that illustrated their lack of specific knowledge and experience, not intelligence by any means, as now making authoritative but seemingly unsubstantiated statements when newbies ask questions regarding these engines and their differences. Still with me? Thanks for being patient.
So here is my scenario:
I have a `98 Bayliner Trophy 2052 that my father and I co-own. It has the 4.3 liter engine and regardless of how it happened, I know that I have a cracked block. Furthermore I`m going to offer an educated guess before I even tear into it that the crack(s) is in the oil galley under the intake manifold because the engine started and ran fine.....until it started to puke frothy oil and water out through the air cleaner. I understand that I have major engine problems and accept that the best case scenario is a short block and worst case is probably a long block, maybe even new manifolds. That situation is what it is, no crying about it now.
The next factor is that by default, everything financial about this boat ends up being my responsibility, even if my brother or BIL are the ones ahhh....using it. That also is what it is.
There is no money in the budget as far as I`m concerned, in the last couple of years I`ve become divorced after a lengthy court battle($) and also experienced about a $25k annual reduction in salary as the corporate bean counters attempt to get my job done without me. Now that`s a long story!......But I still have a ten year old boy who is anxious to get out fishing.
So the bottom line is that a good friend of mine has offered me a Goodwrench crate engine in perfect condition with only 30K miles on it for free. It`s a truck engine if that makes any difference?
Another friend, who is a certified Mercruiser mechanic, says that this engine is a drop and swap without even looking at it. He says that even the cam is the same. He also said that I should replace the gimbal bearing at this time to save going back in later, but he also lead me to believe that this can be done with no special tools. From the little bit of research that I`ve done on the net that doesn`t seem to be true, so now I`m questioning his opinion regarding the direct compatibility of these engines down to and including the camshaft. Would anyone, especially a certified Tech care to offer an educated opinion? Is there anything else I should know or look at?
Sorry for the longwinded post but I want to be clear in the info that I`m conveying and to also reinforce that new marine engines are simply not an option.
Thanks!
Russ"
I`m new here and I
"Hi all,
Thanks!
Russ"
