mcw
"please help
4-3gl (430
"please help
4-3gl (430b V6) 1994 carb tybe
I have now since buying the boat over 3 years ago had a weid problem, which i originaly thought was not a fault.
When starting the engine the fuel pump comes on before the engine at postion 2 of the key switch (position 3 is starting or cranking)
I have thought over the years this is normal, but after talking to a dealer recently it turns out this is wrong and the fuel pump should come on while cranking and remain on while engine is running.until killed by switch or dead mans switch.
For several months now i have traced the circuit diagrame and notice the fuel pump is connected with the starting loom to solind and auto choke on carb, on a yellow wire.
For some weird reasion the purple wire that runs from ignition side on engine(coil) and runs up to the dials is the wire that control the fuel pump under dash board. but the circuit diagrame shown nothing is linked between fuel pump and purple wire its a seperate side of loom.
All relays have been checked, i have metered the loom including continuty checking, i can not find out what is causeing it or even now were to look, i am at a complete stop.
any help or ideas would be realy appreciated or is this normal and just dont worry about it,
the fuel pump cuts of normaly by switch.
what do you think"
4-3gl (430
"please help
what do you think"
