It should not make any difference between the A and B engine. The "flywheel cover" will be the same for either,
and both use a single bearing PDS.
If you went to a double bearing PDS, the flywheel must change to the 153 tooth ring gear.
Pros and Cons:
Single bearing PDS requires the crankshaft centering bushing.
The single bearing PDS is removable from AFT without the need to remove the engine.
This PDS uses a non-serviceable sealed bearing.
The double bearing PDS does not require the crankshaft centering bushing.
The double PDS is removable from AFT but only with engine removal.
These PDS bearings are serviceable via a grease port, and use "open" bearings.
While I like the idea of the serviceable bearings, I think that being able to remove the PDS w/out engine removal, and staying with the same flywheel diameter, would be your best bet.
BTW, if interested, I have a brand new flywheel cover in my inventory, and it is correct for your model.
