"1988 2056 limited renken
4.3
4.3l v6 4bbl carb
50 hrs on new engine
19p prop, usual WOT 4700rpm @ 44mph
Boat has run excellent all season, everything has been flawless. Yesterday i was running about 25 mph at 3300 or so RPM and punched it as another boat approached and immediately it stumbled so i drew back the throttle. The boat recovered with no problem and then i tried it again. It surges anytime i pass 3500 or so RPM or as soon as the back barrels start to open. After looking at the back barrels i noticed the choke was stuck open. after flipping it back down the boat ran great again. Today after 4 hrs or so the same thing happened. This time after checking the carb, everything seemed fine. In fact i watched as the boat was accelerating and the choke/butterfly seemed to opperate properly. Out of gear it has no problem reving or idling. Was told that it could be water in the gas, debris in the carb, or the ignition coil. Any other suggestions before i take it to the mechanic to have the carb rebuilt? Otherwise there are no other problems with lack of power. It planes just fine so long as i dont push it past 3500 or so.
Thank you in advance"
4.3
4.3l v6 4bbl carb
