See earlier post about water i
See earlier post about water in oil. Now I have pressure tested each cylinder with 50 psi air at TDC and looked for bubbles in water were t-stat housing sits. NO bubbles. I removed exhaust manifolds and found both flappers were missing in pipe. Replaced flappers. Ran full speed for 1 hour. Still have steam coming from valve cover vents. Can some water still be left on bottom of oil pan? Temp is 165-170. Dipstick never shows any oil at all. When I change oil I only get a little over 3 qts. out with pump. Engine runs perfect. Never misses on start-up or any time. Where am I getting this friggen water in my engine????
