"91 4.3 omc - runs at 160 with
"91 4.3 omc - runs at 160 with muff. On water will start to overheat going to 200 and would keep rising.
new impeller, new uptake, new thermostat, new water pump - distributor tried. They have also checked head gaskets and replaced. Mechanic thinks small crack in block that causes pressure and reason for water not circulating and wants to replace block, rebuild engine.
Are there other things that should be checked at this point? Is there anyway to measure amount of water/pressure that should be coming up intake hose to thermostat at idle?
Dealer currently has boat and is rechecking above mentioned items but is stumped?
thanks for help"
thanks for help"
