"Rod, the alarm is not soundin
"Rod, the alarm is not sounding like the loud beep sound you hear when you first turn on the key, it is a fant high pitched whistle. The oil is full with 40 PSI, the temp is normal at 160 degrees and the lower unit gear lube is at the max fill line. When I hold the alarm in my hand I can tell the whistle is coming from it. Also the tach problem gets worse when I wiggle the wire on the ingnition switch that feeds the gauges and the alarm. Thanks again for the addition help."
