"First of all thanks to everyo
"First of all thanks to everyone with the help with water getting in the spark plug hole. I think , I hope I have that problem solved.
New issue wouldn't you know.
After running the afternoon on fathers day the engine just died at an idle. It was getting late so I put it up for the night. 2 days later when i had the chance to work on it I had to adjust the air/fuel mixture screws and idle screw to get it to run. Then I thought that I should go ahead a change the fuel / water filter. After doing that I had to re-adjust again. The next day we took the boat out. When starting from a dead stop pressing the throttle all the way down the engine wanted to bog. but you can run at wot for a few minutes. then let up and after about 30 secs accel and it won't bog.
I tried adjusting the 2 air/ mixture screws. With both screws being 1 1/4 turns out. engine spits and sputter thru the carb. Right now I think each side is 2 1/2 turns out. When i first set this setting it seemed to pick up ok. I added 1 pint of seafoam to my gas. today it did ok but still hesitates on load. And it still bogs when first put in the water.
Another issue is when the engine is warmed up you can turn it off. wait 30 secs. then crank it and it cranks ok. But if you wait five minutes you have to cranks the engine for about 4 secs. let off of the starter. then crank again and most of the time it starts.
This carb has been rebuilt. I think the problem is in the 2 air / fuel mixture screws.
Can you guys give me your opinion and also explain the way the air fuel mixture screws work. I know if the screws are out to far the boat won't run right and if they are in to far it won't run right. But I don't know how to tell when I have the proper setting?
Thanks for the help sorry this post is so long but I figure the more info you have the better your able to advise me on how to fix my problem>>"
