suckerswim
"I dont know if you all rememb
"I dont know if you all remember me but i have the inherited 19 ft bowrider that had the starter engaging problems. Well my amazing girlfriend bought me a new starter for my birthday. I installed it and its working great. But like any other sitting boats i am into another can of worms. I am harving starting/idling problems. I have a few questions that i thought you all might be able to give me some help with.
First and foremost there is a choke valve on the top of the carb, correct? I believe that to be so because when i manually controlled it at cold start it helped the boat to start. My main question there is are there supposed to be any springs connected to the linkages for this choke plate? Mine has none on it and it does not seem to be opperating correctly.
Secondly where are the water outputs on the hull? i cant seem to locate them... do the just come out of the outer unit?
Lastly the pcv valves to not seem to connect to anything... they just connect to a flat piece of metal which seems to just bolt on to the spark arrestor bolt? i am just confused i guess. i am an auto mechanic and this motor is not a whole lot like the chevy 4.3
Is there any way to completely drain the fuel tank? I want to have a fresh tank in there and do not want to pump it all out. thank you for all your help."
