40hp mercury wont accelerate
madmax18
Motor shifts into gears fine, R/N/F. It accelerates fine when in reverse, but when I put it in forward it does not accelerate up to full speed. The last outing to the lake I was able to accelerate up to full speed once, but before then and after that one time I was unable to. I am not sure if its something where I have to warm the engine up first or if the linkage is off. But when I take the cover off, the linkage moves the same amount forward as reverse.
Any help would be greatly appreciated. The motor is a 1980 40hp mercury with mercontrols on a bass tracker.
Thanks!
Have you had the cables off at the motor ?-------The shift cable is the first cable that moves.-----------Pushing the handle forward first shift the motor to forward and then as you push forward the motor goes faster.-----Is the motor running on both cylinders.---Compression test done ?
