40hp 402 Mercury spark issues
bcbart82
Hello,
Im looking for some help diagnosing a spark problem on this engine. I replaced the stator last year simply because the wiring was completely rotten. After that i didnt use the boat but it ran on the muffs. I was about to take it out one day and had it running on the muffs and it just died. I checked the orange kill wire to see if it was an ignition problem and that wasnt it. I then removed the two yellow wires from the rectifier and instantly i had spark. I replaced the rectifier and with it hooked up still no spark? Any assistance would be appreciated. (2 years ago i replaced the engine wiring harness due to rotten wires) i have a dva and the only way i can get in spec readings on the stator is to unhook it from the switchbox and rectifier. With the switch box hooked ip its lower and with both the box and the rectifier hooked its even lower.
Bart
Im thinking its my new stator shorting out the ignition circuit once the charge circuit is connected. Just dont want to think that since its a brand new $220 stator!
