hello
go the boat out this spring got the motor running with no issues...went to the lake and it wouldn't start.. had to turn the prime assist switch on the right side of the carbs...it then would start up fine...not sure what to replace...the diaphragm for the prime assist, or the prime starter assy. which runs $180. (how do I test it) ..after it has been running I put the switch back to its original position and it dies. Stays running with the switch on.........runs fine when it runs.
thanks or your time
thanks or your time
