Before I spend too much on parts, I was hoping to get a compression reading on the cylinders. I replaced a bad neutral safety switch, but found the solenoid to also fail testing. I first tried to compression test by using a rope to manually crank the engine, but this old fart can't pull fast enough to get a reading over 60 psi.
I tried running jumper cables directly from the battery to the starter, but can't even get it spinning as fast as I did with the rope.
The battery is a 6 month old 625 crank amp marine battery with full charge.
Next, I yanked the starter and ran it on the bench. It runs full bore like it should, though I know it's not load testing.
I'm figuring my next step is taking the battery to get a load test. If that passes, where go I go from here? I was hoping to not invest in a starter unless I know compression is good. Catch 22?
