40 Merc no spark to top cyl
caseyc
I have what I believe is 97 4
I have what I believe is 97 40 Merc 4cyl outboard s/n OD297257.
I do not have spark to the upper most cyl. I exchanged what I think is the coil with cyl 2 and still no spark on cyl 1? What else should I be considering and any ideas on testing?
"Casey, to start with you have
"Casey, to start with you have a 1993 model.
If your coil is ok then your problem could lie with the stator, switchbox or trigger.
If you drop me an email (click my name) and make the subject your motor, I can send you a pdf file on the ignition system, including tests etc.."
