40 HP Mariner wont idle
jcm11060
Hello,
Been having issues with my 92 40 HP Mariner 4 Cyl. Motor doesn't want to idle. I cleaned the carbs multiple times the past year I have been having issues. I can get it started only with the throttle wide open. I was able to get it to idle by adjusting the idle mixture screws and the idle RPM speed screw.
The last time I put it in the water it ran fine for 30 min and then would not stay running at idle. The gas tank was half full (Pontoon 6 gal. tank) when it started acting up. After the fact I thought it might be related. Could it be a fuel pump issue because it cant pull enough fuel when the tank is lower? I did rebuild the diaphragm pump 2 years ago. Engine compression was 120 on each cylinder when I checked last year.
I'm out of ideas, as soon as I think I make progress I have issues. Any help is very appreciated.
Does, fuel tank have a vent ( screw in filler cap ?)
How many turns out are idle screws turned ? Being you have been through carbs.
No, gas is fresh, carbs were apart and cleaned this year. Yes, high idle lever is all the way up to get it started. Once started I'm able to lower the high idle down.
