Slipperyd12
Bought a boat a few months back it has a 1996 40 hp Mariner (Mercury) and tilt/trim did not work. The electric motor was bad. Motor had been in salt water so all the bolts broke off when trying to remove tilt unit. So I found another unit off of a 60 hp mercury. Electric motor was bad so I replace it and then pressure builds up in the reservoir so I'm thinking a pump problem
So I take the pump off of the 40 hp and install it and have the same problem. I blew air into cylinder and piston works good. It' odd to have two pumps with the same problem. It will blow the fluid back at you when you remove the oil fill plug. Any thoughts on what is my problem would be appreciated.
John.
John.
