40 hp johnson
catmand
"If one is a long shaft and on
"If one is a long shaft and one is a short shaft is it possible to swap out, makeing the short shaft a long shaft. I see there is a spacer, is there also a drive shaft spacer or is the drive shaft a solid longer shaft?"
"yes,..it is....u will need to
"yes,..it is....u will need to chg---
1.dr shaft
2.wtr tube
3.shift conn
4.exhaust ext..
dr shaft,..longer shaft- as weell as all the above."
"I think I will have to do thi
"I think I will have to do this, my other motor is a electric shift and I dont think it would work with the mechanical shift, thanks jwbmarine for the info."
